Creat new parametre for CATIA Drafting TitleBlo macro to link the title block such: name of material
thread560-347233: Change macro to link the title block on name of material
Hi
I read post old.
edite surce code :
Set oMaterial = Part.Paramters.GetItem( "Material" ) ' Root Material
Set oTextToLinkMaterial = Texts.GetItem("TitleBlock_Text_Material_1")
oTextToLinkMaterial.InsertVariable 1, Len(oTextToLinkMaterial.Text), oMaterial
But dont work!
Please helpe me for edite
RE: Creat new parametre for CATIA Drafting TitleBlo macro to link the title block such: name of material
do you set material using apply material or thru additional part properties?
Yes
Where is copy it code?
Sub CATTitleBlockText()
Sub CATLinks()
and where is need edite "Drawing_Titleblock_Sample2.CATScript"?
very thanks
this is how to read part properties
CODE --> catscript
If ProductDrawn <> Nothing Then
    Texts.GetItem("TitleBlock_Text_EnoviaV5_Effectivity").Text = ProductDrawn.PartNumber
    Texts.GetItem("TitleBlock_Text_Title_1").Text  = ProductDrawn.Revision
    Texts.GetItem("TitleBlock_Text_Title_2").Text  = ProductDrawn.DescriptionRef
    Texts.GetItem("TitleBlock_Text_Title_3").Text  = ProductDrawn.Definition
    'Texts.GetItem("TitleBlock_Text_Title_4").Text  = ProductDrawn.Nomenclature
    Texts.GetItem("TitleBlock_Text_Title_5").Text  = ProductDrawn.TITLE.ValueAsString
    Texts.GetItem("TitleBlock_Text_Title_FILE_FOR_MANUFACTURING").Text = ProductDrawn.ReferenceProduct.UserRefProperties.Item("FILE FOR MANUFACTURING").ValueAsString
    Texts.GetItem("TitleBlock_Text_Title_7").Text  = ProductDrawn.Parent.Name
    Texts.GetItem("TitleBlock_Text_Title_8").Text = ProductDrawn.ReferenceProduct.UserRefProperties.Item("DRAWING No.").ValueAsString
    MTRL =ProductDrawn.ReferenceProduct.UserRefProperties.Item("MATERIAL").ValueAsString
    Texts.GetItem("TitleBlock_Text_Title_9").Text = ProductDrawn.ReferenceProduct.UserRefProperties.Item("MATERIAL").ValueAsString
    DrwSheets.Item(i).Views.Item(2).Texts.GetItem("TitleBlock_Text_Sheet_1_all").Text = CStr(nbSheet)
    Dim ProductAnalysis As Analyze
    Set ProductAnalysis = ProductDrawn.Analyze
    Texts.GetItem("TitleBlock_Text_Weight_1").Text = FormatNumber(ProductAnalysis.Mass,2)
  End If
Hi
Very thanks
But no runing!!!!
My file is attach.
Please help me for
1- insert material properties in TB
2- insert company logo in TB
I edit "Drawing_Titleblock_Sample2.CATScript" for material & Logo picture.but don't work.
above i posted the example how to get added properties. we set material in additional part properties
a picture you can add like this
CODE --> catscript
'The following example inserts a drawing picture from a given picture file path The MyView is the active view in the active drawing sheet
 Dim MySheet As DrawingSheet
 Set MySheet = CATIA.ActiveDocument.Sheets.ActiveSheet
 Dim MyView As DrawingView
 Set MyView = MySheet.Views.ActiveView
 Dim MyDrawingPicture1 As DrawingPicture
 Set MyDrawingPicture1 = MyView.Pictures.Add("C:\Program Files\Dassault Systemes\B24\win_b64\VBScript\FrameTitleBlock\TitleBlock_Picture_LOGOKanfit.bmp", 275., 29.)
Hi
Thank you very much
Your code for Picture are very good and used.
I set material using apply material.
But your code for parameter that created in Part or Product properties.
I want insert name of material that material apply in part or product.
Pls help me
Hi JeniaL
I apply material for patr.
Please help me for insert Material name in TitleBlock .
Best Regards
what do you mean by patr?
Hello
: Part
Best Regards
I need inset material name in titleblock that Apply to Part.
such as Part name &...
above code for insert parameter name "MATERIAL" that created new parameter and type by user.
Best Regards
let's make it clear.
firs of all it's not such as part name/part number. part name/part number is a part property and not a parameter.
as i understand you want to assign material to part and then titleblock macro will get this parameter.
i don't really remember how to get parameters. i'll ask some people at work.
maybe guys on this board will help.
