paint parameters command
Hi, i found this new command paint parameters and i am not able use this command. can anyone tell me how to use this command and for type of objects can we use this option.
I created two blocks with different parameters in a part file and i tried to use this command, but i am not able to select any of the blocks.
Thanks in advance
RE: paint parameters command
Do you have the NX help files installed?
If so, press F1 after starting the command.
Don't have NX help files installed? Why not?
The help file will tell you:
Quote (NX 9 help)
Only a limited set of features in the Ship Structure Detail Design application is supported at this time
NX 10 incrementally expands the number of features supported, but all of the supported features are in the ship structure module.
www.nxjournaling.com
