A SMPS transformer question
Hi everyone,
I'm a newbie so please keep the heckling lightweight until I find my feet.
I am working with a push-pull SMPS toroidal transformer design in the 20KW region. The transformer in question has ferrite rings threaded onto the primary and secondary transformer "tails". There are 6 on each primary and 4 on each secondary but on the secondary they are two obviously different types.
I think they are there to increase leakage inductance. What are they there for and how does this work ?
many thanks
Roger
many thanks
Roger
RE: A SMPS transformer question
Now, on some high power designs it is sometimes necessary to put suppression ferrites on the switching devices to suppress undesirable high-frequency oscillations. Such lossy ferrites dampen the ringing.
My guess is that the ferrites you see on the leads are ferrites to suppress HF ringing. This ringing would be seen by the power devices due to the higher parasitic inter-winding capacitance of the transformer. They just happen to be located on the leads of the transformer rather than on the leads of the switching devices. In the design you are looking at the engineer probably found some more leakage inductance was OK if the ringing was suppressed. It may also be that adding the ferrites lowered the frequency of the ring and was a compromise for EMI purposes where you have more emissions margin at lower frequencies.
Yep. I think Comcokid's answer is right on; Big noise suppression beads. hmmm....He might be one of these geniuses who just see's obvious things that many of us don't.
Darrell Hambley P.E.
SENTEK Engineering, LLC
