NX 7.5 navigation panels position on full screen mode
Hello all.
I'm having some difficulty to force loading part navigation panel docked on position I'd like to.
I like to use NX in full screen mode. Almost without menu bars on screen.
Every layout changes and menu bars changes that I did are correctly saved, and after end the program and load it again, the changes are there, except for one panel.
It should be docked on left side of screen, with assembly navigation above and part navigation below it, but every time I load NX the part navigation panel come beside assembly navigation panel.
I've attached two images to best exemplify it.
How can I fix this panel position definitively? Today, every day I need to move it on start of the work day.
Gerson Fioravanti Junior
Mechanical Production Engineer
