ISO free PCB design software
Any recommendations?
RE: ISO free PCB design software
I use Diptrace
http://diptrace.com
They have "free" (non-profit use only) and paid versions (well worth the small cost)
Kicad is another commonly recommended (open source/free)
http://kicad-pcb.org/
I found Diptrace really easy to learn/get up and going and I bought it and use it at work.. (Altium,etc.. are just too costly/feature rich for my needs) but so far Diptrace has done everything I need of it and more.
But most if not all PCB programs don't transfer from one to the other easily if at all..
There is also Eagle which is free for miniscule size boards.
Keith Cress
I may have missed something here, I'm still stuck with PADS-PCB netlists and Gerber output.
Benta.
Benta, I guess this meaning of ISO doesn't really fit in this forum but in this case it meant 'in search of'.
Apart from that, I've been using FreePCB for the last 8 years.
It's free, open source and works very well and is quite easy to use. Nothing much has happened since 2011, but it's stable and I haven't run into any bugs yet.
It needs a PADS netlist as input. Component editor is also included, but the supplied library is quite large.
http://www.freepcb.com/
Cheers,
Benta.
Tried out Kicad this weekend. Fairly easy to pick up and nice little bonus is that it has template PCBs for Arduino etc.
https://www.itead.cc/open-pcb/pcb-prototyping.html
best pricing I've found and quality is excellent..
Keith Cress
Gunnar Englund
www.gke.org
Dan - Owner
http://www.Hi-TecDesigns.com
In the meanwhle, I like DipTrace more and more. Had to create an old metric DIN 41617 board connector and fit metric dimensions to the .1" grid of the PCB. Everything worked like a dream.
Gunnar Englund
www.gke.org
Now we will add resistance values "10kΩ " for all resistors on this schematic. Since "Ω " is a Unicode
character, it doesn't work in vector fonts, which are set by default in DipTrace. We need to activate
TrueType font for part marking in order to use Unicode characters. Go to "View \ Part Marking \
Font \ TrueType". Since TrueType characters look a bit different from Vector on the design area,
you might need to change font size. We made it a little bit bigger.
Now select all resistors then right click on one of them and select "Properties" from the submenu.
Select "Main" tab and type "47 kΩ" into "Value" field. Click on "Markings" Tab and specify "Main
Marking \ Show \ Value", then go to "Additional Marking \ Show \ RefDes" and click "OK".
Gunnar Englund
www.gke.org
Font \<font at bottom of list>) . I don't know how your OS or language selection may affect your results.
http://ntresources.com/blog/?p=1579
Dan - Owner
