Create a sketch using coordinates [Parametric 3.0]
Is it possible to create a sketch using a set of coordinates?
I put the coordinates into a .pts file and I'm able to import the coordinates as datum points as you can see here.
I can use those points to create a curve, but I'd like to be able to be able to use the points within the sketch tool. Is this possible?
RE: Create a sketch using coordinates [Parametric 3.0]
You can select the points as references in the sketch. I don't recall a way to import point coordinates to control sketch points.
