LC1212 ALPHA 2 Parameters
Hi all,
My first time to post here.
I am a newbie on laser cutting machines and i have started recently to read the manual of the recently purchased amada lc1212 alpha 2.
At the beginning when i have first started the machine there was an SRAM PARITY ERROR. I have read the FANUC 16LB manual and it said that i can reset the memory and maybe the error will gone (that was caused because the machine was not working for a long period of time).
After i did that, i have found out that all the previously installed parameters were gone (i had to make a back-up, only if i knew before) and now i have now clue how to put them back and correctly.
Hope someone will help me with their experience or just guide me.
Sorry if my english is bad...not my native language.
Thanks in advance,
George
Thanks in advance,
George
RE: LC1212 ALPHA 2 Parameters
Basically, what was saved on the memory masterboard has been deleted.
I am thinking of taking step by step actions on the machine, maybe i can do something, the only thing is if you dont know, then dont do anything :)
Thanks again
I have put all the parameters that you gave me, Laserninja and the machine is working manually, but at some point it gets an alarm when the x,y or z axis exceeds the limit. I dont know if that supposed to happen or this is how it works manually.
Tomorrow morning i will try again to go a step further, as tonight i will continue reading the operation manual.
thanks again for your unbelievable help.
