Loft using non-planar, not closed curves
Catia V5 R20
I am trying to create a surface using non-planar and not closed curves, as seen in the attached file.
I need to know
1. how to close the curves,
2. make the curves planar in such a way as to not greatly affect the design OR
3. how to create a surface in the same spot, a surface that is tangent to the surrounding surfaces.
I need to know
RE: Loft using non-planar, not closed curves
It all worked. The first time I did not select what surfaces to be tangent to. Now everything is perfect.
Arigatōgozaimash! Hai meiyo!
