Two single phase transformers connected in a bank
So here is an interesting one. I have a customer that has a two single-phase transformers banked together, connected to three-phase primary service.
Configuration is similar to below, except X1/X2/X3 go from left to right.
Couple questions on this configuration. Is it possible to connect this configuration to form Delta-Wye and achieve 120V to neutral on all three phases?
For some odd reason I cannot locate two single phase transformer bank configuration thats connected in a Delta-Wye configuration.
Why can't we connect X2 (neutral) on secondary of both transformers together?
The configuration above give us 240V between all three phases, but only 120V between b-n and c-n, but what about a-n?
Need some help with this one. Thanks in advance.
Jack
RE: Two single phase transformers connected in a bank
What is a-n? A simple bit of geometry, or Pythagoras if you wish, will produce that answer.
With just two transformers you can't have three branches that all meet at a wye point and have an equal phase separation.
On both triangles, erase the A-C and c-a lines, there's no transformer winding there; then some of the rest of it will become clearer.
David, I see what you're saying. What would be the voltage between A phase and Neutral for this situation? 208V?
I don't really care about having a balanced Wye, since we wouldn't have a 3 phase 120V service connecting to anything.
What would happen if I connected both neutrals together?
No you can't get 120:208 three phase from two transformers.
This connection was used to develop 120:240 Volts single phase for lighting and other single phase loads.
The addition of a "Teaser" transformer develops 240 volts three phase for three phase loads.
Typically the transformer connected for 120:240 Volts may be much larger than the second transfoemer.
A hint on the voltage at a-n
Make 120 Volts equal to one unit.
You have a right triangle, n-c-a.
n-c = 1 unit
c-a + 2 units
Solve for a-n
This connection is called an "Open Delta".
This connection is more often used with two primary phases and a neutral.
On long rural lines it saves the cost of installing insulators and conductors for the third phase.
There is a connection that I have heard called the "Winnipeg" connection which will produce 120:208 Volts three phase power from two phases and a neutral but it requires three transformers.
Bill
"Why not the best?"
Jimmy Carter
How do I connect this to 3-phase panel?
I suppose it would be okay if I only had 3 phase breakers/3 phase loads and no 1 PH (1 pole) breakers on the A phase?
How do I prevent someone plugging in a 1 PH breaker and connecting it to neutral?
Put a warning label on the panel? This seems like it would be a code violation to me.
See NEC 408.3(F)(1), High-Leg Identification
You may use two services.
One service will be 120:240 Volts single phase.
The second service will be 240 Volts three phase.
OR
You may use a three phase panel and don't connect any loads between the neutral and the "High Leg" or the "Wild Leg". (208 Volts to neutral.)
Follow up on jghrist's post.
Bill
"Why not the best?"
Jimmy Carter
Thanks everyone this was very helpful!
Jack
