Earth grid testing
Earth grid testing
Can we perform earth grid testing for a substation while it is energized. I have come across some test units that injects current at different frequencies other than 50Hz for this purpose?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Earth grid testing
5. Safety Precautions While Making Ground Tests 5.1 Station Ground Tests:
"It should be strongly impressed on all test personnel that a lethal potential can exist between the station ground and a remote ground if a power-system fault involving the station ground occurs while ground tests are being made." and further:
"For higher ground impedance or greater fault currents, the rise of station-ground voltage may exceed 10 kV.”
Instead of 50/60 Hz you could use 500 Hz tester. See :
http://cindulkar.tripod.com/lab12.pdf
