how to export the catia data to 3dxml with AXIS
Hello all,
I have a question when I export to 3dxml.
I know how to export to 3dxml, but don't know how to export to 3dxml with Axis.
Can you tell me how to make it?! ;D
RE: how to export the catia data to 3dxml with AXIS
Are you talking about V5 / V6 or 3DEXPERIENCE?
What do you mean by '3dxml with axis'
Eric N.
I meant to export CATIA V5 data to 3dxml with axis.
In my options, when I export CATIA V5 data to 3dxml, there is no Axis.
Do you have some ideas?
Solution in online doc. got it within 2 minutes.
Search for "XML Tessellation"
Eric N.
Thanks for your reply.
Yes, I've already tried to convert with "XML Tesselation" option.
But it didn't work.
Also if I convert with "XML Tesselation" option, I can't select a piece of surface.
This means I can't measure the face to face.
Do you konw why it doesn't work?!
Please, help me!!
Sorry maybe I was not clear:
Search for "XML Tessellation" in the online doc
Then read the section you find from the search.
Eric N.
I have a query regarding 3DXML file...When we generate a Clash report,we have a secondary window apprearing on the CATIA Screen,can we export that to 3DXML file..For your reference,I have attached an image below.The red color box indicates the screen which I wrote above.Please look at that and give me your solutions.
