NX Spreadsheet Value Does not Match Sketch Measurement
I recently switched from NX 6 to NX 8 and I have noticed that in some instances, when I change the values of some expressions in the spreadsheet and update the NX part, the expression value does not match the actual measurement in my sketch. It appears that NX thinks it has updated the sketch to the correct expression values but the sketch does not reflect that. Has anyone else seen this before or know what can cause this?
RE: NX Spreadsheet Value Does not Match Sketch Measurement
Can you provide an example part that exhibits this behavior?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
