KPI for Process Engineering Department
Dear All,
As process engineering manager of a petrochemical plant I need some KPI to evaluate the performance of my staff and department. As you may know, Process Engineering Dept. is involved in different activities including:
- Production Planning and Control
- Evaluation and confirmation of technical modifications as well as issue drawings and documents
- Check receive and consumption of feed, utilities and chemicals
- Daily review of process parameters flow, level, temperature, pressure, ...
so, the KPIs and goals or objectives of my department should be aligned with these duties as well as corporate strategy.
Can someone help me in issuing some goals, objectives and KPIs for my dept?
RE: KPI for Process Engineering Department
Cheers
Greg Locock
If you're in an operating plant, maybe you care about downtime, or production, or budget, or something else. If you can reasonably tie those numbers back to an individual, then fine. Maybe everyone's doing similar work of a similar difficulty and you can measure quantity of deliverables, or quickness of response, or hours spent, or something else.
Or maybe there are only five people and a bunch of different type of work that you can't reasonably compare quantitatively. In that case you should pick qualitative things as a way of judging people.
Cheers
Greg Locock
Project files properly configured and kept up-to-date. Measured by checking them.
Project scope document prepared and agreed upon by stakeholders. Measured by checking files for scoping document, stakeholder comments, and resolution of stakeholder comments.
Project scope document updated with each progress submittal. Measured by checking files, etc.
Final deliverable addresses all stakeholder comments. Measured by checking files, etc., and spot checking with individual stakeholders.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
Cheers
Greg Locock
