LMTD calculation for a constant product
Hi everybody
I want to calculate the LMTD for a cooling application in an insulated storage cooling jacket tank .My issue is that the product inside temperature is constant at 4degC and not increase or decrease and the service medium circulated around the jacket is water at tcws=1degC and tcwr=3degC.
Pls’ advice.
Pls’ advice.
RE: LMTD calculation for a constant product
LMTD
ΔTA = 4 - 1 = 3oC
ΔTB = 4 - 3 = 1oC
Can you clarify your issue?
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
Good luck,
Latexman
