Give your opinion
Give your opinion
Give your opinion
As a new Pressure vessel designer what would be best for start working, current pressure vessel project or totally new project?
RE: Give your opinion
I would recommend working on what your boss wants you to work on.
Which (since you are the newbie on the plant, in the office, or behind the boiler room insulation) will probably be the dirtiest, scuzziest, most cold (or hot!) least comfortable position possible. In 20 years (in 4 years) you will need experience working in new design, replacement, repair, and overhaul.
Go get dirty, get a good batch of humility under your belt, before you try selecting the choice jobs.
Choose the job with the better boss and / or the better mentor, if you have the choice.
Whatever you are doing for a job at the moment, stay with it until you become more competent, then you can be more selective.
"....current pressure vessel project or totally new project?": not important
Try a company with: international expertise, prestige, a serious way, culture......etc
r6155
