Macro_searching a Geo Set item by name - help
I have a script that finds a Geo Set by a certain name, and proceeds to extract information from that set. The problem I discovered is that the code - 'Set Level1 = OriginPart.HybridBodies.Item("Fasteners")' will actually find the first set with the string "Fasteners" in the name; such as "Upper_Fasteners_Bolts". Since it is finding the first occurance of the string "Fasteners" in the name, I my not get to the Set I'm looking for. I have added code to catch when the set is not correct by name; however, I have not figured out how to move on past that 'false set'
Is there a way to make it find just the set that is called "Fasteners" and ignore sets with the string "Fasteners" within a longer name?
Or,.... is there a way to make it proceed past that 'false item' and move on to the next occurance of "Fasteners" in a name? If I go back to search the item name again in the script, it just finds the first occurance in the tree again....
