NX Advanced nonlinear analysis fatal error
Hi, I´m trying to run an advanced nonlinear analysis on FEMAP 11.2.2 and i get the following fatal error (see attached image), do anyone know what can be the problem?
When i see in the folder were femap is running there is a file with *.op2 extension, but the name its the same than the model file.
The model is composed by solid linear hexahedric elements, solid tetrahedral (10 noded parabolic), beam elements, rigid connections, glued contacts and contacts (not glued).
