Drafting - Copy And Translate
I am new to CATIA 5. I want to copy and translate a line and some text. So, I opened up a current drawing and I go to "Insert", "Geometry modification", "Transformations" and "Translate". The Translate function asks for the geometry I want to translate, and I pick it. And, I pick the text I want to copy and translate, also.
But, then I don't know what to do to exit out of the menu so I can pick the point I want to translate from and to.
Or, am I in the wrong function to do this?
RE: Drafting - Copy And Translate
2. then select the translate command
3. select the Duplicate option and number of copies
4. select the reference point
5. select the go-to point
