Code returns wrong reference set and volume...
I have a strange problem. I am currently using component.ReferenceSet to return the reference set of model parts in an assembly.
However in a particular model part, it returns the wrong reference set and number of solid bodies in the set.
It should return the MODEL ref set, however it is returning the Entire Part ref set, as well as 2 solid bodies instead of what should be 1.
I am also running Measure Bodies to calculate the volume. The volume is correct for every part in the assembly except this one part. The volume should be 1.38 cu. ft.. However my code produces 41 cu. ft.
So I tried using some different code to get the ref set, I used: refSetName.
It produced a different result, but still the wrong one. It said that the ref set was "NONE" and that there was still 2 solid bodies in the ref set.
If you like you can see the portion of my code that looks for the ref set below.
My hunch is that this particular part was made using Trim Bodies, and because of that it is also calculating the volume of the part that it is connected to. That still does not explain the ref set problem. However even then I am not sure, because if that were true, in NX there would be more than 1 solid body in the ref set.
theUfSession.Assem.AskComponentData(temp.Component.Tag, partName, refSetName, instanceName, origin, csysMatrix, transform)
objExcel.cells(row, 13) = temp.Component.ReferenceSet
or
objExcel.cells(row, 13) = refSetName
Both produce different results...
or
RE: Code returns wrong reference set and volume...
To test your "trim body" theory, have you created a new part that uses trim body features to see if it gives the same type of error when used in the assembly?
www.nxjournaling.com
Do you mean the solid body is modeled in the assembly file?
