Sort combination list
Dear friends,
Anyone know how to sort the combination list in an specific order?
RE: Sort combination list
Try exporting Combos table to Excel and reorder them as you wish.
In SAP, delete all the combos and then import the previously rearranged Combos table.
It should do the trick.
Thanks for your answer. Your trick doesn´t work. When I try to import the reordered list of combos I get a lot of warning messages like this: "Combo type not recognized; record skipped"
Thanks for your help
Hi nachohp,
I have just tested in my computer what I suggested and it works fine.
According to the type of warning messages you received, it looks like you did something wrong while editing the Excel file (maybe you deleted a line, or copied and pasted some other line in the wrong position, e.g.).
Try again and be careful to respect the right sintax and order of the Excel file.
I assure you it works!
I have deleted the GUI column and import it again and works.
