Premature Failure of Gas Compressor Bearings
I have a CP 550A gas compressor which is seizing after 30 minutes of running. The bearings after 10 minutes look like they have months of run time on them. Our mechanics have been meticulous in rebuilding the compressor holding the closest tolerances that they can. We have rebuilt this compressor 5 times, replacing crank, bearings, connecting rods, cross heads, and line boring the frame. And still the connecting rod and main bearings are failing. It appears that the bearing are starving for oil but we can get anywhere from 60 to 110 psi of oil pressure and when the oil pump is actuated by hand when get oil throughout the system.
Hoping someone on here might have some ideas.
Craig
Craig
RE: Premature Failure of Gas Compressor Bearings
when the lube oil pipe was re-installed, the gasket was inserted without a center hole punched. yeah, the blower ran for about 15-minutes before we were going to shut it down due to high lube oil temps, but it seized first. not a pretty sight and we ended up cutting the shaft in two to remove from the blower. not a pleasant activity out in the middle of the ocean.
check the path from pump to bearing to be sure of no obstructions (i.e. blow air through lube oil piping).
hope this helps and good luck.
-pmover
As I have spent my career working with gas compressors, including a fair bit of failure analysis, its possible that I can provide some more assistance with a lot more detail of the compressor and its operation.
Will
