ANSYS Workbench Parameter Analysis help
Hi Everyone!
The problem is the following:
I want to plot a Response surface where the X axis is the subjected specimen area. The problem is that, i calculate the area from two another input parameter, and the program automaticali put the area parameter as an output parameter, so i can only plot it, in the Y axis.
Any suggestions?
