symbol in NX 7.5
symbol in NX 7.5
I work with NX 7.5
and I need a symbol, rectangle with 2 oval ends with number in it. Another symbol is the same but with black ends. We put it beside each dimension and use to refer to specific dimension when on the phone call.
How I can create such a symbol.
I never did, so to be really helpful please give me instruction step by step, if possible.
Thanks a lot
Thanks a lot
RE: symbol in NX 7.5
For myself, if I never plan to use this symbol within a line of text (as Annotation), then I'd create a custom symbol. The how-to's are available in the NX documentation under Custom Symbol.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
I would like to create my own symbol stating from nothing.
But how I can add a number to the symbol so after inserting many of them into the drawing I can just double click (or .. edit) and change the number
For the Balloon, enter the size of 8 and I'm guessing letting height of 2 - if not, use whatever height you want, but the taller you make it, the taller the Balloon will become.
For a Custom Symbol with editable text, you'll have to draw the geometry and place the note where it needs to go. When you're in the Define Custom Symbol dialog, set the Text Attributes pulldown to Arbitrary. This will allow you to change the text value to whatever you want.
All the info you need for Custom Symbol is in the NX Help docs under CAD -> Drafting -> Custom Symbols (at least that's what it is in NX9).
Either method should give you what you want. See the attached - the top one might be what your 4 X 8 Custom Symbol looks like after you go through the steps of defining the Custom Symbol correctly. The bottom shows an 8mm Balloon for comparison. Either way will probably give you what you want (if the shape is correct).
Tim Flater
NX Designer
Now the problem is how to save that symbol into the library so I can use it on other drawings too?
If you don't, just open a new part without any templates (if possible), recreate the symbol and set the symbol library to part. Define the symbol, etc. and then place 1 symbol in that part and save it somewhere easily accessible. To use it in another file, just open the saved part & copy/paste the symbol into the destination part. That's what I have to do because my NX admins like to lock the users out of everything (for the most part).
Tim Flater
NX Designer
