PN160 SLIP-ON FLANGES
Hi Guys,
A little help here if you will; I'm looking for slip-on flanges for PN160 and more rating. DO these exist? I see mostly up to PN100 rating and not more.
Thanks, hope to hear your advice.
RE: PN160 SLIP-ON FLANGES
I wouldn't like to see a 160 bar slip on flange.....
Additionally, some applications will not accept slip-on flanges for this pressure depending on the other parameters. You need to check the piping specification to be able to use this concept.
In case the cyclic load is available or the application has high fluid temperature the slip-on flange is not recommended. Some codes do not accept (if my memory is correct) slip on flanges on gas applications beyond certain pressure and temperature limits. So check your application for the slip-on flange suitability.
