PUMP & INSTRUMENTS ON HAZARDOUS AREA
Hi guys,
I have an ATEX-rated air operated double diaphragm pump including the air filter regulator and PSV. On the area classification plot plan, it is shown that it is under Cl 1, Div 2. My AODD is fine I believe since it is ATEX rated already. How about the instruments included in this equipment? Is there any such provisions for regulators and relief valves that they can be designed according to this area class? Or is it fine not considering area class for instruments?
PS: These PSV and filter regulator will be on the air line side of the pump.
Thank you in advance,
Virata.
Virata.
RE: PUMP & INSTRUMENTS ON HAZARDOUS AREA
Spring relief valves without sensors are Ok, it then depends on what sensors or controllers you have on the "regulator". Some are wholly pneumatic or self contained, others have 24V sensors and controllers. they need to be suitably certified for the area you are located.
you really need to get this reviewed by a suitable instrument and electrical engineer.
http://www02.abb.com/global/seitp/seitp202.nsf/0/8...
http://www.eng-tips.com/
