Flat collar vs. collar on flanged connection
Consider a flat collar, like this:
http://www.erv-gmbh.at/en/flanges-collars-butt-end...
and a collar, like this:
When to use one over the other and why?
The flat collar is welded around the pipe, the collar to the face of it. Does this matter down the road?
I don't have acces to the DIN EN 1092-1
The background of the question is that we specified flat collars and the contractor installed collars. When I raise the issue in house, I want to have asked the stupid newbie questions beforehand so I turn to you. But please leave contractor and coworker relations etc. to me, in this thread I only want to know the relevant technical diffferences.
RE: Flat collar vs. collar on flanged connection
I can only assume that the welding of the flat collar is similar to that of a slip on flange - see this page http://www.wermac.org/flanges/flanges_welding-neck... and scroll down to slip on flange.
As such it seems to create quite a heat zone in a small ring with consequential issues over workmanship (i.e. potential to over heat the flat collar). The flat collar also has fillet welds which are more difficult to NDE, there are two welds, the outer weld needs to be only a certain size to prevent the flange ring from bearing on the weld instead of the flat collar and getting alignment would seem to be more problematic.
Collars on the other hand are a simple butt weld - easier to inspect and probably easier to install, which is probably why your contractor used the other type.
Personally I would always use the collar as I trust butt welds above fillet welds and unless you can't butt weld there for some reason would seem to be a better plan to me. I've never really liked slip on flanges for that reason as well.
In terms of codes, they are both the same so it comes down to preference, testing and ease of installation / construction cost.
The flat collar is indeed slip on
from: http://www.heco.de/edelstahl/flansche/boerdel-und-...
I don't see the welds on the drawing, but as the front of the flat collar seems to be flush with the face of the pipe I assume one fillet weld?
If you only have a short stub available then they look Ok, but otherwise, as I said, there's no real code difference so it comes down to cost and timing.
The slip on flange calculated strength for internal pressure is approximately 2/3 of welding neck flanges, and their life under fatigue is about 1/3. The connection with the pipe is done with 2 fillet welds, one weld at the outside and one on the inside of the flange.
The OP was asking for our opinion on the difference but both end up with a backing flange ring which can rotate.
The second one is a stub end used with a lap joint flange:
These flange connections are applied, in low-pressure and non critical applications, and are a cheap method of flanging. In a stainless steel pipe system, for example, a carbon steel flange can be applied, because they are not come in contact with the product in the pipe.
bimr, in my browser your links where broken (404).
This discussion has me puzzled when flat collars are more apropriate.
As with most things it comes down in part to cost and part practicality.
Once the cost of welding the collar (stub end) and the cost of the stub end exceeds that of the flat end and the additional welding then it might start to become attractive (depends on the material used). Also when you have a thin pipe and only a short distance available you can save a few mm by this option.
Otherwise I would always go for what you call the collar, but many would call a "stub end".
