Repair of corrosion hole on nozzle
I have a storage tank with a corrosion hole on the neck of a manway nozzle located at the base of the tank.
653 tends not to give much guidance on repair methods so I'm wondering what might be the best course of action might be. The corrosion hole is small (1" x 1") and the surrounding area has good metal remaining.
I'm thinking of cutting out an area of the nozzle and placing a patch in. Is this right, and if not, what other courses of action might be appropriate?
Devin
Devin
RE: Repair of corrosion hole on nozzle
r6155
