How to use the Maximal Principal strain as a predefined field for a new calculation.
I would like to make first a mechanical calculation, get the maximal principal strain in a output database,
then read the output database with a new study, and make a
conductivity field
833 1
Where the first field will correspond to the maximal principal strain.
Thanks.
X d'Estève.
RE: How to use the Maximal Principal strain as a predefined field for a new calculation.
Use a report to write out the result extrapolated and averaged at the nodes and use that for the initial condition of the field variable.
Thanks for your repply.
I tried with *INITIAL CONDITIONS, TYPE=FIELD, VARIABLE=1, INPUT=result.rpt,
but i get a lot of errors. I tried also with FILE , but this option requires a .fil.
Well, read the messages and fix the problem.
I feel that the option INPUT only take .inp files as arguments.
This is the error message :
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown assembly node set FIELDOUTPUTREPORT
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown assembly node set SOURCE1
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unrecognizable assembly set/id ---------
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance node set ODB:C:/USERS/DESTEVEX/DESKTOP/PB_MECANIQUE/JOB-1.ODB
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown assembly node set STEP:STEP-1
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name FRAME:INCREMENT1:STEPTIME=1
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown assembly node set LOC1:INTEGRATIONPOINTVALUESFROMSOURCE1
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name OUTPUTSORTEDBYCOLUMN"Element Label"
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown assembly node set FIELDOUTPUTREPORTEDATINTEGRATIONPOINTSFORPART:PART-1-1
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance node set ELEMENTINTE.MAX.PRIN
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown assembly node set LABELPT@LOC1
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unrecognizable assembly set/id -------------------------------------------------
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Invalid instance id "11186.075E-06"
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name 11186
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Invalid instance id "21185.445E-06"
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name 21185
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Invalid instance id "31186.735E-06"
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name 31186
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Invalid instance id "41181.526E-06"
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name 41181
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Invalid instance id "51185.709E-06"
Error in job Job-1: in keyword *INITIALCONDITIONS, file "Job-1.inp", line 385: Unknown part instance name 51185
Thanks for the advice, my problem is solved.
