HELP counterbored standard
Hi all,
i've just decided to sign to this community.
I need your help!
I feel sick about searching every day the standard dimension for DIN172 cemented bush with collar and manually set dimensions of all counterbored holes, depth, type and so on...
Is it possible to create something like a standard, macro, env (i don't know what!) that could help me? I want to set all this standard dimension in to a excel file just one time and catia should take dimension from that file!
Could you give me some advice?
Thanks!
RE: HELP counterbored standard
you could use knowledgeware or script.
After creating a Hole, you would change the feature name to DIN172, then KWA or script would do the job.
Eric N.
Thanks JeniaL & itsmyjob.
