2 plane balancing without trial masses
Hi
Can someone explain how dynamic balancing machines determine the "trim weight" required without using trial weights? There is an example in this video http://erbessd-instruments.com/Eng/video.php (2 Planes Balancing of Turbocharger Rotor) that illustrates this. How does the machine accurately determine the location of the heavy spot and its location?
thanks
dynaman
thanks
dynaman
RE: 2 plane balancing without trial masses
Cheers
Greg Locock
Using complex maths
response_at_plane1=TF11*UB1+TF12*UB2
response_at_plane2=TF22*UB2+TF21*UB1
note that TF12=TF21 by reciprocity
Cheers
Greg Locock
Sorry what are UB1 & UB2 exactly? Is there a reference that explains this method in detail?
thanks
Mark.
Yes I think the Bruel and Kjaer blue book on vibration analysis has a pretty good section on this method. http://www.bksv.com/doc/bn1330.pdf
Incidentally I'm not entirely convinced that TF12=TF21, that'd be an interesting check. Specifically if the accelerometers are not pointing in the same direction then I can imagine the phase relationship between the two would change.
Cheers
Greg Locock
Cheers
Greg Locock
Cheers
Greg Locock
Cheers
Greg Locock
