Hydraulic Counterbalance Valve Circuit
Hi! I have involved in a hydraulic system design which used for winch pull.
Specification as below:
1. Hydraulic Cylinder: Bore: 320mm x Rod: 200mm x Stroke: 1600mm @ 2 unit
2. Counterbalance Valve.
The hydraulic cylinder mounted horizontally.
Please advice my design.
Thank you.
Thank you.
RE: Hydraulic Counterbalance Valve Circuit
If you want someone to review your design and give you advice you need to take it to a senior engineer who understands the application.
http://hydraulicspneumatics.com/other-technologies...
