Typical Moment Connection
Hey everyone, just wondering if anyone has some thoughts/insight as to what type of moment connections are being commonly used in practice. I know a lot of it depends on seismic design considerations, fabrication cost, ease of erection, ect. I am just looking to get a feel for what people are using in their designs.
GD
GD
RE: Typical Moment Connection
1) Extended end plate moment connection.
2) All bolted flange/web plate moment connection.
3) Welded flange/web plate moment connection.
In all cases, I'll avoid having column continuity plates if possible. I may even up the column size to make it possible.
My best advice is to call one or several fabricators in your area or area of a particular project. There is a lot of value in talking with them ahead of designing your connections.
Can you elaborate on this? I've mostly only used them for small scale stuff where, I've assumed, the columns could be drawn together or pushed apart. I'm not sure what mechanisms would provide for tolerances in larger scaled applications. Fab short and shim?
-GD
