Abaqus, Visualization problems, Composite Solid
I am simulating a flywheel energy storage system consisting of two rims and one hub. Therefore I am using three parts, two of them have as many partitions as layers (up to 75 but only 0 degree plies). Additional a press fitting is simulated in the first step. In the second step a rotational force up to 40000rpm is simulated. The simulation runs, no errors BUT if I want to look on the results something "weird" happens. The solid rims (but not the hub) appear faceted (see attached picture)and after one day of searching for the error I hope you can help me
The whole system is scrypted in Python (which I attached too). So everybody can run the simulation (on my laptop around 10min) and investigate the result.
picture of result ODB: Link
Python Script: http://workupload.com/file/fzEJCRLB
Thanks very much in advance,
Michael
Michael
RE: Abaqus, Visualization problems, Composite Solid
In mesh modul you can check the stack direction that with Tools -> Query and change it with Mesh -> Controls (or button).
You are right, I forgot to change the stack direction. Problem solved!
Thank you.
