Plot Frequency Response
I would like to post-process a frequency response analysis in order to have the plot of the response vs frequency. I mean once I get the results by Nastran, how can I plot the Displacement vs Freqency in Femap? In my analysis output there is a case for each frequency at which I have found the response, but now I need to plot the displacement as a function of the frequency.
Any suggestion and opinion is welcome. Thank you very much all!
Emanuele
RE: Plot Frequency Response
To make plots with Femap you have to use the charting option. When you click on it, a window will open, then select the symbol xy to open antoher window where you can choose what to plot
