MCC Vertical Bus Split
I recently received copies of a clients single line drawings of several MCCs which show as many as 3 vertical bus splits dispersed throughout the arrangements. I have never encountered this before and cannot think of any practical reason this should be done. In some cases, there are "vendor-installed" jumpers connection both sides of the split to the main horizontal bus. In other cases, there are no jumpers, leaving large portions of the MCC with no apparent connection to the vertical bus and thus without power.
I'm wondering if anyone else has ever seen this, i.e. splits in the vertical bus, and what would be the reason for it?
RE: MCC Vertical Bus Split
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
Thanks for the feedback JRAEF.
