Abaqus python through command line: Error message "ImportError: No module named ******"
Hi everyone,
I'm trying to run Abaqus through a command line with abaqus python d:\file.py. However, I receive the following error message:
CODE --> Python
Traceback (most recent call last):
	File "file.py", line 1, in <module>
		from part import *
	File "SMAPython\SMAPytLibPy.m\src\site.py", line 120, in _numpyHook
		"""Append ./build/lib.<platform> in case we're running in the build dir
ImportError: No module named part
file.py looks as follows (and I receive the same error for all of the Abaqus-modules I want to import; it works for other, standard modules):
CODE --> Python
from part import *
from material import *
from section import *
from assembly import *
from step import *
from interaction import *
from load import *
Unfortunately, I couldn't find any solution online and would really appreciate your help. Thank you very much!
RE: Abaqus python through command line: Error message "ImportError: No module named ******"
You run the script from the command line, so it has no access to CAE related module, methods or objects.
If you need that, you may run the script through CAE but without starting the GUI. Should be something like that:
abaqus cae noGui=file.py
Thanks so much for your quick response - it works like a charm!
Another quick question: When I have the batch file, e.g. run.bat, with content abaqus cae noGui=file.py in the same directory like the file.py, it can't find it ("abaqus error: the following file(s) could not be located: file.py"). It only works if I specify the directory, like in: abaqus cae noGui=C:\file.py. Is there a way to set it to the same location the batch file is in?
Thanks a lot!
A batch file is executed in a Windows default directory, not locally. Place the following command at beginning of you batch file, to redirect the execution directory.
set WORKING_DIRECTORY=%cd%
I also added cd %~dp0 in front of the line you mentioned, which reads the actual location of the .bat file. Now it seems to work. Thanks very much!
CODE -->
cd %~dp0
