difference between wrought steel and wrought iron
what is the difference between wrought steel and wrought iron. I know wrought iron has less than 0.08% carbon in it. Is there any carbon percentage that defines wrought steel or is it just forming process of steel.
RE: difference between wrought steel and wrought iron
Steel is an alloy of Fe and C, with lots of other additions. See the def above.
Wrought Iron refers to a product that has been produced with a low C and a significant amount of iron silicate and/or iron phosphate in the structure as stringers.
