NX9 Journal for .EXE File
I posted some months ago about this same problem.
http://www.eng-tips.com/viewthread.cfm?qid=377516
One of the problems coming to a solution was that due to privacy issues I was not allowed to post anything with the name of the company who made the .exe file nor the name of the file. So I was even told by my bosses that I couldn't post the details of the error.
Well due to the fact they are pushing me to get this done now, I am going to try and post the details of the error and just X out any info I believe could be a privacy problem. And hope I don't miss any. lol
When I go to FILE - EXECUTE - NX OPEN and select their file, it will run perfect and at the end, a dialog box will open for me to choose an option of how to continue. These options will work perfect. HOWEVER, if I use a macro that runs the EXE file the same way, the file seems to work fine until the option dialog box opens up. Then it does not continue when I select my option. Because the file runs as soon as I select it in the recording, I never get a chance to stop recording until the program is done. I tend to think that the macro is still trying to run while the program runs and it causes a problem with selecting options.
In the thread I linked to above, someone gave me a journal code to run the program. Others tried it for other programs and it seems to work for them, but for this program it gets an error....
Microsoft .NET Framwork
The type initializer for "XXXX.Main' threw an exception.
DETAILS.... (Note* Any privacy possibilities have been replaced with XXXX)
************** Exception Text **************
System.TypeInitializationException: The type initializer for 'XXXX.Main' threw an exception. ---> System.IO.FileNotFoundException: Could not load file or assembly 'NXOpen, Version=9.0.0.19, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
at XXXXX.Main..cctor()
--- End of inner exception stack trace ---
at XXXX.frmReport.sCreateReportHeader()
at XXXX.frmReport.frmReport_Load(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
I am hoping someone might know by this info what I can do or try, to fix the problem. Whether anyone can help or not, I want to thank you ahead of time for any effort you put into this.
RE: NX9 Journal for .EXE File
If so, I think phillpd gave you the answer in your previous thread...
So, why are you trying to start the exe with a macro?
What we are trying to do is to use a TBR file and create buttons that can simply be opened on their computers and all are connected to one source. Then updates and installs will be simple. Unfortunately, I can only get the TBR file to run Macros or Journals. I messed around with just directing it right to the exe file and that doesn't seem to be an option from what I read on-line.
Some speculation on my part:
Since it is an exe file, it was probably meant to run in 'batch' mode. Perhaps it needs the file name to process passed to it as a 'command line argument'. This doesn't explain why "execute -> nxopen" works with the file, perhaps the "execute" command automatically passes the current file to the exe? I'm not sure.
If the help file examples don't work in this case, it might be time to call GTAC. They would be in a better position to analyze your setup.
www.nxjournaling.com
