Error message: Unable to Expand Pressure from Load Definition 1 onto Surface xxxx in Load Set 1
I am trying to apply pressure to a group of surfaces, where some of them are boundary surfaces. The load it seems to be applied and the results are the expected, I get however the following error message before analyzing the model
Any help would be appreciated
BR Alexandros
BR Alexandros
RE: Error message: Unable to Expand Pressure from Load Definition 1 onto Surface xxxx in Load Set 1
Always before solving is better to do a PREVIEW ANALYSIS to see if FEMAP is able to write the nx nastran input file with success, if not the error in red will appear in the message area. In your case the meaning of the message is clear: you are free to apply pressure loads in any surface geometry, but if you forgot to mesh then the error ... OK?.
Best regards,
Blas.
Blas Molero Hidalgo
Ingeniero Industrial
Director
IBERISA
48004 BILBAO (SPAIN)
WEB: http://www.iberisa.com
Blog de FEMAP & NX Nastran: http://iberisa.wordpress.com/
