Pole Base Plate Corner Cuts
We have a pole base plate with the corners cut at 45 degree into he anchor bolt holes on the base plate. It appears that these have been done for a reason. Is this just a fabrication thing? Is there a purpose for these cuts at the corners?
RE: Pole Base Plate Corner Cuts
1) Something to do with galvanizing.
2) Something to do with outdoor durability.
3) Something to do with installation tolerances.
@JAE: imagine a regular, square base plate with four AB in the corners. Draw a line from the each bolt hole out to the nearest corner. Now make that line a 1/2 slit cut into the plate. Add a slight chamfer to the plate at the corners and you're there. OP to confirm..
I'm changing my answer to this.
1) If it's an outdoor highways structure, often it'll have the slots.
2) If it's an outdoor building structure, it'll never have the slots.
I suspect that this something where building engineers can pick up some smart detailing tips form our transportation brethren. Hopefully one of them will show up here.
This would explain why I see his in highway structures but not outdoor building structures.
thread726-275699: Cuts in Light Pole Base Plate
