Import from SAP2000 to SAFE
Hello Friends
Need some help. after importing the foundation forces (Multiple column supports) and moments to SAFE from SAP2000, what I find the LOAD WIND and Earthquake are not imported. Earthquake is defined as response spectrum and wind load as user specified. Dead, Live load above the defined elevation (at fnd level) and Modal loads are imported correctly. Where I have gone wrong.
Your suggestion will be helpful.
Raj
Raj
RE: Import from SAP2000 to SAFE
A good structural engineer is often a blessing for others.
