SolidWorks Beam Simulation Crashes
hello All,
i have one model of assembly consisting more than 40 Beams and a few solid as bracket and solidworks simulation premium 2015 SP02.
i made a set up for simulation, doing it from contact set (beam - solid) till the external force.
i meshed the model with curvature based mesh and get the mesh process done, but it will crash "everytime" i begin to run the simulation. :(
it just doesn't happen in one computer, but with every computer that i use. is there something i should check to make static analysis so it would run normally?
i noticed that crash happen when "transferring misc. data.." process, right after mesh process and the windows of solver didn't event appeared yet.
p.s. : the file size is around 2 Mb, not quite large, due to privacy policy i couldn't uploaded it here. is there anyone here ever faced the same problem?
