Electric Grill Design
Im trying to design an electric grill to boil water in an open tank.
I need an advice on KW/ m2 to use for this purpose.
R
RE: Electric Grill Design
Yes, i cant use immersion heaters it must be a grill underneath the tank.
Its for 16000 liters and in 8 hours period.
To boil water in a container, you have three, commonly used options:
1) ELECTRIC IMMERSION HEATER: Inexpensive to purchase, easy to control, Can be made permanent or "drop in"... Very common
2) INTERNAL STEAM COILS: Inexpensive to operate, must have steam available, Control is slow
3) EXTERNAL PADS (Electric or steam) A bit slower to heat liquid, somewhat more expensive than internal devices
4) CIRCULATING PUMP WITH EXTERNAL HEATER: Most expensive option, heater can be steam or electric or gas, very close temperature control
Explain more about your needs. What temperature does the liquid start out at ?
Are the sides of the tank available for heating ?
Can immersion heaters be dropped into the open top of the tank ??
Is the tank insulated ???
MJCronin
Sr. Process Engineer
Thanks MJ,
Answering your questions:
No nothing can be inside the tank and neither in the sides of it, neglect all heat loss from the walls.
T1 = 15C T2 = 100C
I just need an idea on the KW/m2 for the grill underneath the tank.
My thought is the heat from convection plus radiation must equal the waters specific heat for that delta T and volume
No school, Stuff,
I need to quote this for a client, were OEMs
And Im just thinking of heat transfer principles
Thx
Do you see anywhere the suggestion of KW/m2?
No, then question not answered
If you neglect all heat loss from the wall then you will be wrong.
The per square meter part of the answer will depend on how many square meters you have. You either don't know, or have forgotten to tell us this part.
Other than his sloppy use of "/" to mean "and", IRStuff has explained how to approach the problem.
