Creating Dimension to Gage Point
I am trying to create a linear dimension to a gage point, however since the part is oriented at an angle, I am unable to get the dimension to go in the correct direction. See the attached picture. The black lines are the dimension that I would like to put in. Any tips on how to do this?
NX 8.0/TC8
RE: Creating Dimension to Gage Point
Tried Perpendicular & Horizontal dimensions?
If nothing works better to add a reference line.
Use "parallel" dimension and use the "direction" option to define the direction vector.
