Truss Analysis
Truss Analysis
I am currently working on analysis of Truss structure. I am using the beams for modelling. As most of the beams are connected to one another in pinned joints, how do I make my joints in pinned configuration? I understand that the constraint function in the Femap is tying the node to globally and not locally. Is there ways to make the node joints locally pinned? Thanks
RE: Truss Analysis
RE: Truss Analysis
RE: Truss Analysis
RE: Truss Analysis
if you Have to use beams, use freedom releases at the ends.
