Remember last current feature?
The situation is this (and happens often). I'm using Make Current Feature to edit a feature deep in the Part Navigator. After finishing the editing, I make the last feature (the one that resides at the bottom of the part navigator) current to see what effect the change has on the entire part. If I'm not happy with the change, I want to go back and edit that same feature again. Now I need to go searching for this feature which is a hassle, especially with lots of feature groups. It's like looking for a needle in a haystack.
In Solidworks there is a handy command that allows you to go back to the last "rollback bar position", which is the perfect command for this situation. Is there something similar in NX? Another way to do it? Can a journal do this?
NX10.0 Win8.1 64bit i7-3770K 16GB QuadroK2200
RE: Remember last current feature?
www.nxjournaling.com
http://www.eng-tips.com/viewthread.cfm?qid=388572
