Mitsubishi ceiling fan.
I have a number of mitsubishi ceiling fans in the house, they are 4 speed controlled by a rotary wall mounted speed controllers.
1 of the units is now running very slowly on the lower speed. Other speeds are ok and it doesn't appear that it is mechanical, on shut down the fan rotates freely for what seems like a normal rundown period.
As yet I haven't looked at or checked anything but tomorrow I will open the rotary switch and have a bo-peep. I am assuming there will be contacts for each speed position and will be looking for dirty/ burnt / damaged contacts.
Any further ideas or suggestions for the low speed.
RE: Mitsubishi ceiling fan.
Thanks again.
"You measure the size of the accomplishment by the obstacles you had to overcome to reach your goals" -- Booker T. Washington
CR
