Checkerplate Available Thickness Load Tables
I'm looking for a reliable resource for Raised Pattern Floor Plate aka "Checkerplate".
AISC Tables 3-18a & b gives allowable loads. But, is checkerplate typically available in all these thicknesses?
Thank you!
RE: Checkerplate Available Thickness Load Tables
I recommend you contact a local (local to the project) steel fabricator and inquire with them. They would be in the best position to speak about product availability.
If it's a small quantity, call around and see what's available. Typically "Diamond floor plate" (little chevron patterns at right angles) rather than checkerplate (little X's).
