Design of Flocculator - particle number and diameter
I'm currently working on a design for a mixing and flocculation facility (I'm a student) for a potable water treatment plant. I managed to desegn a fast mixer for mixing of coagulant but I'm having difficulties designing the slow mixers (for flocculation).
I want to calculate the reduction of number of particles over time in the unit operation I designed but for this I need the number of particles per unit volume(n) and their average diameter (d). I've got some influent details like FTU and SI but I that's it. I also need to have a realistic collision efficiency (a).
The equation I found for reduction of number of particles over time is: -dn/dt = (4*a*n^2*d^2*Gv) / 3
But I guess a more complete formula is: -dn/dt = (8*a*n*cv*Gv)/ PI
I also found these two formulas: n/no = e^(-ka*cv*Gv*t) (for flugflow) and n/no = 1/(1+ka*cv*Gv*t) for completely mixed systems
Gv = Velocity constant (already calculated)
cv = volumetric concentration derived from n and d
ka = no idea
I want to know a couple of things:
What does the ka value stand for?
What are realistic values for n and d for Meuse river water with a settling time of 3 months? Otherwise can I derive n and d from another parameter of my influent?
Wich one of the fomulas should I use?
What is a realistic collision efficiency rate (a)
By the way. I'll pobably design multiple flucculator following each other with reducing rotation speeds consecutive to reduce floc breaks.
ka = no idea
RE: Design of Flocculator - particle number and diameter
Other textbooks such as Water Supply and Pollution Control by Mark Hammer have examples of these calculations.
Ka is the aggregation coefficient
http://www.ecs.umass.edu/cee/reckhow/courses/371/3...
http://www.rc.unesp.br/igce/planejamento/download/...
