Is there a journal that can make simplification in part or assembly_
Is it possible to make a Journal that will make a box (using block feature if possible) that is enveloping (if this is correct word_ like a wrap just wrapping box, not wrapping surfaces) the model or selected assembly components. Then put the box in reference set "Box" and put it on layer 2?
Is it necessary to know programming languages to be able to make Journals?
Thanks.
Thanks.
RE: Is there a journal that can make simplification in part or assembly_
But Wrap Assembly is something that should help you here.
If you are using NX 10, you can use the "create box" command to make an associative block around the geometry you select.
There is a form of the command in NX 9 as well; see:
thread561-377786: NX9 Bounding Box function
www.nxjournaling.com
I am sorry I skipped this in first post.
Thank you, it looks very good in NX 9 video.
